borgward
#1 Posted : Saturday, December 28, 2013 7:28:20 PM(UTC)
borgward
How do I replace the temperature sensor? I can see that it unscrews from inside the oven, but how do I get to the cable behind it to unplug it? Is there a service manual for this oven? I have the owners manual.
borgward
#2 Posted : Sunday, December 29, 2013 7:12:01 AM(UTC)
borgward
I found end of sensor cable behind the electric oven and under sheet metal cover. How do I determine sensor is faulty? I could remove the sensor and subject to a known temperature and then measure voltage or resistance. I do not want to buy another sensor if it is not the problem.
The oven stays on about 15 minutes then turns off. I can turn it back on, but it will only stay on for a shorter time. Next time it turns off immediately. I am getting no error codes. The oven temperature is close to accurate. Same behavior with the broiler. Cleaning function does not work at all.
#3 Posted : Monday, December 30, 2013 3:20:28 AM(UTC)
Below is a site with sensor info.
Check out 7, 8, 20 and 21.
http://www.applianceaid.com/ele...-range-repair-topics.php
If the unit is coming ready then it could be the sensor.
If it always stays in pre-heat then it is probably something else.
RT29K5030WW/EF SAMSUNG fridge temperature sensor (Refrigerator & Freezer Repair)
by Guest 3/26/2024 1:32:30 AM(UTC)
1970 GE electric wall oven (double oven) broken temperature sensor (Oven Repair (including Ranges and Cooktops))
by zea3 6/21/2022 1:48:00 PM(UTC)
Temperature Sensor Replacement Part of late 1960's GE wall oven (Oven Repair (including Ranges and Cooktops))
by Guest 4/6/2022 7:18:23 AM(UTC)
Temperature Sensor for General Electric GTS22KBPDRCC Frost buildup (Refrigerator & Freezer Repair)
by trm655 11/18/2021 12:53:19 PM(UTC)
how do I replace temperature sensor (Oven Repair (including Ranges and Cooktops))
by imchas 6/2/2020 12:24:26 PM(UTC)
Where is the Freezer Temperature Sensor on My GE Profile Side-By-Side? (Refrigerator & Freezer Repair)
by TSJim 9/15/2019 6:14:16 PM(UTC)
Oven gets too hot, it's not the temperature sensor (Oven Repair (including Ranges and Cooktops))
by joymsburton 2/9/2018 4:30:36 PM(UTC)
Oven Temperature Sensor Beyond F3 (Oven Repair (including Ranges and Cooktops))
by salquint 10/31/2015 8:36:13 AM(UTC)
Need to order a Temperature sensor (Oven Repair (including Ranges and Cooktops))
by JennyP 4/25/2014 6:20:05 AM(UTC)
Temperature sensor faulty ? (Refrigerator & Freezer Repair)
by danny713412 7/26/2013 10:35:50 AM(UTC)
GE Monogram Refrigerator - Temperature Sensor Issues (Refrigerator & Freezer Repair)
by Gaucho100K 6/10/2013 6:02:25 PM(UTC)
How to install temperature sensor and defrost sensor (Refrigerator & Freezer Repair)
by mhart 4/7/2013 7:09:38 PM(UTC)
Change Temperature sensor (Refrigerator & Freezer Repair)
by spoony 4/17/2012 11:27:09 AM(UTC)
Temperature sensor issue (Oven Repair (including Ranges and Cooktops))
by Stan Stevens 6/14/2011 9:33:48 AM(UTC)
Oven temperature sensor (Oven Repair (including Ranges and Cooktops))
by Sanco777 5/11/2011 4:37:57 AM(UTC)
