Stan Stevens
#1 Posted : Tuesday, June 14, 2011 12:33:48 PM(UTC)
Stan Stevens
I have an F3EO error code which supposedly corresponds to a defective oven temperature sensor probe. The display panel will not show current oven temperature (room temp) and the oven will not function. I replaced the sensor with FSP part #W10181986 which I recently purchased from APP. However I still get an F3E0 error code. I checked the contacts from the control board to the sensor and all seem OK. I'm at lost what to do next. Is it possible that the new probe is defective? :(
#2 Posted : Wednesday, June 15, 2011 6:39:21 AM(UTC)
Replacement parts for WHIRLPOOL WFE381LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN | AppliancePartsPros.com
Although not common it is not unheard of to get a bad part from a manufacturer.
Though it is common enough that I always check parts before installing them.
Here is a good link with sensor info.
http://www.applianceaid.com/elecrange.html
Check out 7,8, 20 and 21.
If the sensor checks out OK,
Recheck the connector on the board.
You may have a cold solder joint. Usually they are a duller silver or may have pin holes. Also wiggle the connector while looking at the solder side of the board to see if the connector pins move in the solder.
A magnifying glass helps here and is also useful when looking for hairline cracks in the solder trails.
If all is OK then odds are your control board is toast.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
WFE381.pdf (258kb) downloaded 7 time(s).
You cannot view/download attachments. Try to login or register.
Stan Stevens
#3 Posted : Wednesday, June 15, 2011 10:22:08 AM(UTC)
Stan Stevens
Denman- Thank you for your thorough reply. I have checked the electrical resistance and continuity of the old and new oven temperature sensors and both tested OK. I also checked the solder contacts at the control board and they appear to be very solid. I've come to the conclusion that my control board is defective. I have placed an order for a new control board. Could you give me an idea what could have caused the control board to fail? Thank you for your help.
#4 Posted : Wednesday, June 15, 2011 11:44:52 AM(UTC)
[COLOR="DarkRed"]Could you give me an idea what could have caused the control board to fail?[/COLOR]
Cannot really say as with any electronics part components do fail.
tj_fixit
#5 Posted : Thursday, July 12, 2018 4:00:53 PM(UTC)
tj_fixit
very very common issue is Power outages. the electronics have little protection for the significant power voltage spikes that accompany power outage/restoration from the electric company. (if you do not have a whole house surge protector that can handle the 50000 Volt minispike as the grid reconnects)
lost two control boards (oven and washing machine) before i figured this one out. (culprit was the line transformer that failed when PG&E was trying to diagnose a variable voltage on one leg, that i reported)
of course they take no responsibility for failed appliances. and insisted right up to the catastrophic failure that there was nothing wrong, and that i couldn't have detected it anyway.
GE Monogram Refrigerator - Temperature Sensor Issues (Refrigerator & Freezer Repair)
by Gaucho100K 6/10/2013 9:02:25 PM(UTC)
