Replacement parts for WHIRLPOOL WFE381LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN | AppliancePartsPros.comSee the attachment for the tech sheet.
Is it possible that the new probe is defective?
Although not common it is not unheard of to get a bad part from a manufacturer.
Though it is common enough that I always check parts before installing them.
Here is a good link with sensor info.
http://www.applianceaid.com/elecrange.htmlCheck out 7,8, 20 and 21.
If the sensor checks out OK,
Recheck the connector on the board.
You may have a cold solder joint. Usually they are a duller silver or may have pin holes. Also wiggle the connector while looking at the solder side of the board to see if the connector pins move in the solder.
A magnifying glass helps here and is also useful when looking for hairline cracks in the solder trails.
If all is OK then odds are your control board is toast.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
