White72gs455
#1 Posted : Tuesday, December 24, 2013 1:19:55 PM(UTC)
White72gs455
2 year old gas dryer won't stay running
If I press the start button it start and stops right away, pulled the back off and pulled the lint screen tube to check for obstructions. If I hold the start button it will run and then gas fires up. I can hear the motor click from start windings to run windings. Drum spins. Seems to work fine as long as I hold the button, as soon as I let off the start button, it stops...
Any help out there?
White72gs455 attached the following image(s):
#2 Posted : Wednesday, December 25, 2013 1:38:35 AM(UTC)
Parts for Maytag NGD4600YQ2 / - AppliancePartsPros.com
Most likely it is a problem with the centrifugal switch on the motor.
It should close and provide an alternate/parallel circuit path to the motor's run winding letting you release the start switch.
The switch may have a problem internally as you do hear it actuate.
I would still check that this end of the motor is clean as often it is just the centrifugal mechanism in the motor is not working due to lint/dirt.
Note that the switch is not available as a separate part so the motor has to be replaced.
Kenmore electric dryer won't stay running (Dryer Repair)
by steve37887 10/25/2019 4:52:25 AM(UTC)
Dryer won't stay running after replacing parts (Dryer Repair)
by dlg56 11/6/2016 6:54:36 PM(UTC)
Dryer won't stay running... (Dryer Repair)
by Charlie.2loose@gmail.com 7/26/2015 7:29:52 AM(UTC)
Whirlpool Gold dryer won't stay running and no heat (Dryer Repair)
by swami69 4/7/2014 10:15:38 AM(UTC)
Admiral Dryer Won't Stay Running (Dryer Repair)
by ravynfire 10/16/2012 6:51:07 AM(UTC)
Dryer won't stay running (Dryer Repair)
by OKFREE 4/23/2011 7:35:37 AM(UTC)
by JimRumler 1/31/2011 11:28:26 AM(UTC)
by hollyparrish 1/26/2011 7:35:43 AM(UTC)
by timjmix11 10/5/2010 6:04:45 PM(UTC)
Dryer won't stay running. (Dryer Repair)
by nwpop05 1/13/2010 2:21:38 PM(UTC)
by MONA SMITH 11/15/2009 7:19:33 PM(UTC)
by Fixitchick 9/24/2009 4:12:27 PM(UTC)
by teetwofalcon 8/8/2009 3:34:19 AM(UTC)
GE Electric Dryer won't stay running (Dryer Repair)
by bdrg 1/8/2009 8:09:06 AM(UTC)
Bosch dryer won't stay running - sometimes (Dryer Repair)
by jhabetler 3/2/2008 1:17:47 PM(UTC)
