Our Amana bottom freezer refrigerator is having problems! It runs great, no strange noises, the compressor runs just fine. Then the temperature gets warm in both the frig and freezer and the compressor isn't running. I turn the freezer setting control off & back on, the compressor kicks on and and the temp is fine again, 0 to -10 degrees (freezer) for a few hours, then it quits & gets warm again & the compressor isn't running, once again I turn the freezer setting control off & back on and the temp is fine once again for a few hours.
Model #AEB1905CCO May be the Refrigerator Temperature Control? On my Amana it is part# 67003000.
thank you for any advice!
Today our Amana has not stopped running to the point where it begins to get warm. But, the freezer goes from -20 to +25 degrees!
Originally Posted by: jbs1  Today our Amana has not stopped running to the point where it begins to get warm. But, the freezer goes from -20 to +25 degrees! ..and my finger are crossed!
Originally Posted by: jbs1  ..and my finger are crossed! The Refrigerator Temperature Control took care of the issue, the temps are constant and the frig is stocked once again. I hope this might help someone else down the road.
