we had just taken a load out of the dryer. we put another load in and went to start it and nothing went on. there is power coming in but nothing works, not even the light.
Here are your parts Parts for Maytag MEDC400VW0 Dryer - AppliancePartsPros.comSee the attachment for the wiring diagram How do you know that the unit has power? Did you measure 120 volts (Neutral to L1) at the terminal strip in the unit. This is the side of the line that powers the light and motor. If yes to the above check the door switch. |
THIS FORUM IS DEAD!!!!!!! |
