mikeuhn
#1 Posted : Wednesday, September 25, 2013 4:47:55 PM(UTC)
mikeuhn
we had just taken a load out of the dryer. we put another load in and went to start it and nothing went on. there is power coming in but nothing works, not even the light.
#2 Posted : Thursday, September 26, 2013 5:00:56 AM(UTC)
Parts for Maytag MEDC400VW0 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram
How do you know that the unit has power?
Did you measure 120 volts (Neutral to L1) at the terminal strip in the unit.
This is the side of the line that powers the light and motor.
If yes to the above check the door switch.
Maytag centennial washer- motor won’t spin (Washer Repair)
by Guest 3/30/2024 1:59:24 PM(UTC)
Maytag Centennial 2010 Top Load does not spin (Washer Repair)
by Guest 8/20/2023 4:45:18 PM(UTC)
Maytag Centennial will not always start (Washer Repair)
by Guest 7/6/2023 6:59:54 PM(UTC)
Maytag Centennial Washer MVWC415EW0 Agitation issue (Washer Repair)
by Guest 5/27/2021 9:58:45 PM(UTC)
Maytag Centennial (Model MVWC300XW1) (Washer Repair)
by zenitramsa 8/9/2020 10:32:59 AM(UTC)
Maytag Centennial Top Loading Washer Agitator Issue (Washer Repair)
by BluEclipse17 2/15/2020 7:56:31 AM(UTC)
Maytag Centennial Commercial washer (Washer Repair)
by kuowengdds 3/27/2019 10:50:48 AM(UTC)
Maytag Centennial Only Spins (Washer Repair)
by YANCEYTX 3/3/2018 9:48:01 PM(UTC)
maytag centennial washer (Washer Repair)
by arodriguez01 2/6/2018 8:29:06 AM(UTC)
maytag centennial washer low fill (Washer Repair)
by redjada 9/3/2017 9:01:47 AM(UTC)
Maytag Centennial problems (Washer Repair)
by beezerboy 8/1/2017 10:44:36 AM(UTC)
maytag centennial electric dryer not drying/heating anymore (Dryer Repair)
by lloyd raymond martin 6/7/2017 5:34:16 PM(UTC)
Maytag Centennial MVWC200BW0... a computer problem? (Washer Repair)
by Mark531 6/6/2017 6:25:58 PM(UTC)
Maytag centennial stuck at wash cycle start (Washer Repair)
by aljuaid86 5/18/2017 1:20:44 AM(UTC)
Maytag Centennial Agitate But No Drain (Washer Repair)
by ralphj 5/8/2017 6:33:14 AM(UTC)
