ashkdaot
#1 Posted : 12 years ago
ashkdaot
our GE washer has leaked all over the laundry room and the tub seems loose. Could the water pump need to be replaced or what should we try first?
sidfink43
#2 Posted : 12 years ago
sidfink43
Take off the front cover by inserting a screwdriver in the gap between the top and front near the edges to release the clips that hold the front panel on.
You should be able to see the source of the leak, but if not start up the machine with the front panel off and you should be able to determine where the problem is.
With luck it will only be a hose connection or broken hose. It is probably not the pump.
Handyman Randy
#3 Posted : 12 years ago
Handyman Randy
Two common problems for GE's are as follows:
1) Hose from outter tub to pressure switch can get a clogged.
a stiff wire (metal hangor or long nail) can remove the clog.
2) Bad Pressure Swtch (Load Size Switch).
Remove hose from outter tub and blow in it you should hear the switch click as you blow and let the air out.
both problems can cause the washer to over fill.
Leaking Washer (Washer Repair)
by midget73 11 years ago
by broonsparrow 11 years ago
Leaking washer need advice (Washer Repair)
by GE Nightmare 12 years ago
by Jags 12 years ago
leaking washer (Washer Repair)
by martha725 13 years ago
leaking washer and won't drain (Dishwasher Repair)
by colt 13 years ago
leaking washer (Oven Repair (including Ranges and Cooktops))
by cheery 13 years ago
Leaking washer (Washer Repair)
by Crowell 14 years ago
leaking washer during filling (Washer Repair)
by bonnetinsurance 14 years ago
by 03svrider 14 years ago
by rcarroll7703 14 years ago
by donandlynn 14 years ago
by Mrkis 14 years ago
by Clueless101 14 years ago
by wirenutt2 14 years ago
