broonsparrow
#1 Posted : 11 years ago
broonsparrow
I've a hot point washing machine that had a damaged paddle - it came off and some clothes got jammed between the drum and the outer casing when pulling the clothes out I think I damaged something at he bottom of the drum because when I ran the machine it leaked! I've removed the paddle and I can feel a loose piece of metal under the drum and can stick my finger into a hole that feels like it has a ball in it? Any idea what I have damaged and if it's repairable?
TIA
sidfink43
#2 Posted : 11 years ago
sidfink43
What you did should not have damaged the machine, maybe you just have a leaky hose.
Anyway if you will post a model number we can tell you how to open it up and check.
Leaking Washer (Washer Repair)
by midget73 11 years ago
Leaking washer need advice (Washer Repair)
by GE Nightmare 12 years ago
leaking washer (Washer Repair)
by ashkdaot 12 years ago
by Jags 12 years ago
by martha725 13 years ago
leaking washer and won't drain (Dishwasher Repair)
by colt 13 years ago
leaking washer (Oven Repair (including Ranges and Cooktops))
by cheery 13 years ago
Leaking washer (Washer Repair)
by Crowell 14 years ago
leaking washer during filling (Washer Repair)
by bonnetinsurance 14 years ago
by 03svrider 14 years ago
by rcarroll7703 14 years ago
by donandlynn 14 years ago
by Mrkis 14 years ago
by Clueless101 14 years ago
by wirenutt2 14 years ago
