my front load washer makes a terrible racket when it gets to full speed. the first time it happened it was smoking when I opened the door. I removed the clothes and when I spun the drum it felt like something was caught between the drums. Now it spins fine until it reaches max speed, then it sounds like it is coming apart. Where do I look? :confused:
If there is not something between the inner basket and outer tub then it may have bad bearings.
