my cambrio washer recently became louder on the spin cycles, any ideas on what to replace?
The tub bearing is the likely suspect, but check out the pump first.
You will need a repair manual to replace the bearing and unfortunately I cannot link you to one. See if one is available for downloading for free or at a small cost.
