ezonana1
#1 Posted : Thursday, January 31, 2008 1:25:14 PM(UTC)
ezonana1
I have a brand new screech-ie sort of noise that just began at start of spin cycle & continued throughout spin. Spin completed OK & I have not used since - don't want to destroy anything that is avoidable. Will appreciate suggestions on where to start to diagnose problem and correct as easily (and economically) as possible.
Only service in past 4 years - I replaced coupler (with some difficulty) a bit over a year ago. Thanks for any help you can offer
#2 Posted : Thursday, January 31, 2008 3:37:47 PM(UTC)
Possible a foreign object in the drain pump.
Remove the cabinet, remove the drain pump, bypass the lid switch and run the spin cycle.
If there is no noise - replace the drain pump.
If it's still noisy - let us know and we will go further.
- The part number for the drain pump is AP2907492
ezonana1
#3 Posted : Thursday, January 31, 2008 7:28:38 PM(UTC)
ezonana1
I really appreciate the very prompt reply. Can you also direct me to a blow-up showing most efficient way to remove cabinet (& pump)?
Thanks again,
Eli
#4 Posted : Thursday, January 31, 2008 9:34:33 PM(UTC)
Hi Eli,
I hope these instructions will help.
ezonana1
#5 Posted : Saturday, February 2, 2008 7:12:16 AM(UTC)
ezonana1
Thank you so much for your help, Gene. No noise on spin after I took the pump off the motor drive shaft. When I took the bottom hose off, a small 1" brad/nail fell into the catch-pan. The pump impeller looked good through the water connectors, so I washed pump out thoroughly (no more foreign objects), reinstalled with perfect, QUIET function. I suspect this may have shortened the life of pump impeller, but OK for now.
I will check my pockets on shirts & pants more carefully from now on. Again, my sincere thanks.
Eli
#6 Posted : Saturday, February 2, 2008 8:00:51 AM(UTC)
Hi Eli,
I'm glad you were able to fix it.
GE Washer - Noisy Spin Cycle (Washer Repair)
by jbblack 6/22/2021 4:47:04 AM(UTC)
Whirlpool Calypso slow, noisy spin cycle (Washer Repair)
by supergm7 11/16/2015 4:22:13 PM(UTC)
Noisy Spin cycle (Washer Repair)
by JamesO 5/4/2013 2:29:37 PM(UTC)
Noisy spin cycle (Washer Repair)
by stellaweezy 5/4/2013 1:44:20 PM(UTC)
by justinw 12/16/2012 6:30:54 AM(UTC)
by minka1333 2/8/2012 11:25:38 AM(UTC)
by Dolly1 1/12/2012 4:15:09 PM(UTC)
by Danrepair 12/1/2011 8:24:57 AM(UTC)
Maytag Washer Noisy Spin Cycle and Agitate (Washer Repair)
by Joseph_igallegos 6/1/2011 3:32:44 PM(UTC)
by bgdadd 4/2/2011 9:35:54 AM(UTC)
by Paul March 4/1/2011 4:50:36 PM(UTC)
Noisy Spin Cycle on level machnie (Washer Repair)
by malibu3426 10/27/2010 9:22:09 PM(UTC)
Noisy Spin Cycle (Cabrio) (Washer Repair)
by tedbuck 9/22/2010 8:27:13 AM(UTC)
Front Load Frigidaire With Noisy Spin Cycle (Washer Repair)
by mb250c 7/6/2009 2:04:50 PM(UTC)
by psmith 12/9/2007 1:31:26 PM(UTC)
