Dale1970
#1 Posted : Monday, February 4, 2013 9:17:06 AM(UTC)
Dale1970
We have replace the heating element, the control panel, checked all four thermostats, the 220 volt coming into the panel, the thermal fuse, but how do we check the plate sensors in this model? Or do you have any ideas what else it could be
Simon / APP Team
#2 Posted : Monday, February 4, 2013 11:22:48 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Have you replaced the main control board DC92-00382B?
The heater relay is incorporated in this control and may be bad. It's #2 with BLK and BLUE wires. See if you can jump this two wires. Be careful - it's 240VAC.
Also check the motor contacts 1-2 (red wires). With the motor running they should be closed.
Simon.
Dale1970
#3 Posted : Monday, February 4, 2013 12:24:50 PM(UTC)
Dale1970
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
We replaced the board but the part # was DC92-00384e did we order the wrong one?
Simon.
Simon / APP Team
#4 Posted : Monday, February 4, 2013 1:18:42 PM(UTC)
Simon / APP Team
Groups: APP Team
I'm afraid so.
If you got it from the APP you may return it back.
Still do the test I suggested before ordering the new one.
Simon.
Dale1970
#5 Posted : Monday, February 4, 2013 1:48:51 PM(UTC)
Dale1970
I'm afraid so.
Simon.
Ok great how do I jump the wires while it's plugged and put together
Dale1970
#6 Posted : Tuesday, February 12, 2013 11:12:22 AM(UTC)
Dale1970
OK I changed the control panel and still no heat :confused:
Simon / APP Team
#7 Posted : Tuesday, February 12, 2013 12:39:29 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Let's start from the top.
I need you to follow my recommendations, please:
- check for 240VAC at the dryer's conector block
- remove Blue wire from the heat relay of the main control board (make sure it's not touching any metal surfaces)
- turn the dryer on, calling for heat
- use the multimeter to check for 120VAC first from the relay contact to the ground and then from the Blue wire to the ground
- if you have 120VAC from the relay and not from the Blue wire, trace the blue wire down to the thermostats
- check continuity with one wire taken off the thermostat
- if thermostats are fine, the heater is new and all connections are good you need to check if L2 Red wirer from the connector block brings the 120VAC to the motor switch
- everything checks OK - you have a bad motor switch in which case best to replace the motor
- if there is no proper voltage at the heater relay - check the thermistor. At room temp. the resistance should be about 10K ohm.
Simon.
mky130
#8 Posted : Thursday, February 14, 2013 6:02:45 PM(UTC)
mky130
Hi.
- check continuity with one wire taking off the thermostat
Simon.
I myself am having the same problem with kenmore dryer. All is ok except the things you've just mentioned. Can you please tell me how to check the back contacts so I don't kill myself?
Simon / APP Team
#9 Posted : Friday, February 15, 2013 8:50:55 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
What is the problem and complete model number?
Simon.
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
by chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
