checked all the wiring, checked incoming voltage, checked heating element all are ok. one or two of the thermostats are bad... what's the proceedure for checking them ( 4 ). The dryer runs it just doesn't heat
Here are your parts Replacement parts for GE NBXR333EG0WW | AppliancePartsPros.comSee 507 in the "Cabinet" section, this is a thermal fuse that may be blown. To check: Unplug the unit. remove one wire from the thermostat or fuse. Check it with a meter should be 0 ohms at room temperature. If the fuse is blown be sure to clean/check the blower wheel, give the interior a good cleaning and clean/check the vent system. |
THIS FORUM IS DEAD!!!!!!! |
