tominski
#1 Posted : Tuesday, September 29, 2009 2:02:52 PM(UTC)
tominski
checked all the wiring, checked incoming voltage, checked heating element all are ok. one or two of the thermostats are bad... what's the proceedure for checking them ( 4 ). The dryer runs it just doesn't heat
#2 Posted : Wednesday, September 30, 2009 4:27:31 AM(UTC)
Replacement parts for GE NBXR333EG0WW | AppliancePartsPros.com
See 507 in the "Cabinet" section, this is a thermal fuse that may be blown.
To check:
Unplug the unit.
remove one wire from the thermostat or fuse.
Check it with a meter should be 0 ohms at room temperature.
If the fuse is blown be sure to clean/check the blower wheel, give the interior a good cleaning and clean/check the vent system.
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
by chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
