KarenSep
#1 Posted : 12 years ago
KarenSep
My washer will not fill with water. When I add water to it from a hose, the machine will go through it's cycles until it gets to the rinse cycle and then I have to use the hose to fill it up again. I am guessing that the water valve needs to be replaced. Could I be right?
Simon / APP Team
#2 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
Please, provide the correct model number. This one doesn't come up.
Simon.
KarenSep
#3 Posted : 12 years ago
KarenSep
Should be Model #LAT9700AAW
fairbank56
#4 Posted : 12 years ago
fairbank56
Groups: Expert
There is a fuse in the lid switch assembly that will blow if the lid switch fails. This prevents the washer from filling. If the fuse is blown, you can just temporalily jump it out. It is not there for circuit protection. It's only function is to render the washer inoperable (can't fill) in the event the lid switch fails in the closed position. If it's the fuse, just replace the whole lid switch assembly. The assembly includes a new lid switch, lid check switch and fuse/fuseholder. The switch is located under the control panel.
Eric
Frigidaire washer will not fill. (Washer Repair)
by Elwood44 4 years ago
Dishwasher Will Not Fill With Water (Dishwasher Repair)
by sfora71 9 years ago
ge washer will not fill error code 10 (Washer Repair)
by Jimverbe 9 years ago
Washer will not fill for Rinse Cycle (Washer Repair)
by KLS2015 10 years ago
Maytag Washer will not fill (Washer Repair)
by creeves 10 years ago
Whirlpool washer will not fill with water (Washer Repair)
by mdavis1218 11 years ago
washer will not fill, only drain (Washer Repair)
by crodenburg 11 years ago
Dishwasher will not fill (Dishwasher Repair)
by sultan62 12 years ago
GE Washer will not fill (Washer Repair)
by Hock 12 years ago
Kenmore 665.13893 Dishwasher Will Not Fill - New Water Inlet (Dishwasher Repair)
by ferant316 12 years ago
by pbhall 12 years ago
Washer will not fill or wash (Washer Repair)
by rrobleto 12 years ago
Whirlpool Top loading washer will not fill (Washer Repair)
by jeffjbrown 12 years ago
by Annv 13 years ago
washer will not fill with water on any cycle but still runs on spin cycle help (Washer Repair)
by Paul Linville 13 years ago
