sultan62
#1 Posted : 12 years ago
sultan62
I recently moved a Kenmore Dishwasher model no. 363.14589100 that worked fine, and after moving I cannot get the dishwasher to fill. I have checked the pressure right before the water inlet valve, and it is adequate. I have checked the screen filter at the water inlet valve, and have tested the valve for continuity as well as the wiring coming in to the valve for voltage. All of this appears to function correctly:
Voltage: ~120V
Resistance: ~1100Ω
If anyone has any tips, it would be appreciated. I'm getting tired of washing dishes by hand. :(
#2 Posted : 12 years ago
Since the fill valve has 120 volts across it when it should be filling. I am assuming this is what you mean by "Voltage: ~120V" and does not open.
I would replace the valve.
sultan62
#3 Posted : 12 years ago
sultan62
Even though the valve shows continuity?
#4 Posted : 12 years ago
Yes.
Just because the solenoid coil has continuity does not mean that the plunger pulls down opening the orifice re: it could be a mechanical problem in the valve.
sultan62
#5 Posted : 12 years ago
sultan62
Thanks-I'll check it and post back.
sultan62
#6 Posted : 11 years ago
sultan62
I just came back with another appliance question and realized I didn't respond to this thread. For that I apologize.
I don't have anything helpful to add to this thread, as I came across a functioning dishwasher that I could have for free provided I hauled it away, so I never did order an inlet valve or otherwise solve the issue with the old dishwasher. Thanks again for the help provided.
Dishwasher Will Not Fill With Water (Dishwasher Repair)
by sfora71 9 years ago
Kenmore 665.13893 Dishwasher Will Not Fill - New Water Inlet (Dishwasher Repair)
by ferant316 12 years ago
Dishwasher will not fill with water (Dishwasher Repair)
by field.chuck@yahoo.com 13 years ago
My dishwasher will not fill w? water (Dishwasher Repair)
by fhomefixer 13 years ago
Dishwasher will not fill (Dishwasher Repair)
by Jbrobbins83 14 years ago
Kitchen Aid Dishwasher will not fill (Dishwasher Repair)
by mdcook 14 years ago
dishwasher will not fill w/water (Dishwasher Repair)
by rde750 14 years ago
GE dishwasher will not fill with water! (Dishwasher Repair)
by joyelizabeth 14 years ago
Maytag Dishwasher Will Not Fill With Water (Dishwasher Repair)
by jwpurdy 14 years ago
GE Dishwasher Will Not Fill (Dishwasher Repair)
by kodiak_dude 15 years ago
dishwasher will not fill (Dishwasher Repair)
by wledswift 15 years ago
by nancyrice 16 years ago
bosch dishwasher will not fill water (Dishwasher Repair)
by loas 16 years ago
Bosch Dishwasher will not fill (Dishwasher Repair)
by gundogofct 16 years ago
Bosch Dishwasher Will Not fill with water (Dishwasher Repair)
by drskinner 17 years ago
