rrobleto
#1 Posted : 12 years ago
rrobleto
when I press start the green light of filling goes on, also the red light of the lock, it makes some noise inside the tub but it does not fill, I removed the clear plastic hose from the pressure switch and put air pressure on the switch and nothing, can I get any suggestions please?. Thank You
rrobleto
#2 Posted : 12 years ago
rrobleto
I heard a clicking noise and the shifter is trying to shift all the time, I am suspecting that the transmission is the problem, because I found a little bit of oil on the cover, how can I test it?, thanks, please help
