KarenSep
#1 Posted : Monday, December 24, 2012 1:23:59 PM(UTC)
KarenSep
My washer will not fill with water. When I add water to it from a hose, the machine will go through it's cycles until it gets to the rinse cycle and then I have to use the hose to fill it up again. I am guessing that the water valve needs to be replaced. Could I be right?
Simon / APP Team
#2 Posted : Monday, December 24, 2012 3:39:30 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please, provide the correct model number. This one doesn't come up.
Simon.
KarenSep
#3 Posted : Monday, December 24, 2012 8:10:47 PM(UTC)
KarenSep
Should be Model #LAT9700AAW
fairbank56
#4 Posted : Tuesday, December 25, 2012 6:54:50 AM(UTC)
fairbank56
Groups: Expert
There is a fuse in the lid switch assembly that will blow if the lid switch fails. This prevents the washer from filling. If the fuse is blown, you can just temporalily jump it out. It is not there for circuit protection. It's only function is to render the washer inoperable (can't fill) in the event the lid switch fails in the closed position. If it's the fuse, just replace the whole lid switch assembly. The assembly includes a new lid switch, lid check switch and fuse/fuseholder. The switch is located under the control panel.
Eric
Dishwasher Will Not Fill With Water (Dishwasher Repair)
by sfora71 10/7/2016 8:29:08 AM(UTC)
ge washer will not fill error code 10 (Washer Repair)
by Jimverbe 1/28/2016 7:58:07 PM(UTC)
Washer will not fill for Rinse Cycle (Washer Repair)
by KLS2015 6/28/2015 9:05:48 AM(UTC)
Maytag Washer will not fill (Washer Repair)
by creeves 12/28/2014 12:41:20 PM(UTC)
Whirlpool washer will not fill with water (Washer Repair)
by mdavis1218 1/17/2014 6:47:34 AM(UTC)
washer will not fill, only drain (Washer Repair)
by crodenburg 10/29/2013 1:46:23 PM(UTC)
Dishwasher will not fill (Dishwasher Repair)
by sultan62 4/9/2013 10:08:39 AM(UTC)
GE Washer will not fill (Washer Repair)
by Hock 3/31/2013 7:27:11 AM(UTC)
Kenmore 665.13893 Dishwasher Will Not Fill - New Water Inlet (Dishwasher Repair)
by ferant316 1/28/2013 3:18:58 PM(UTC)
by pbhall 1/17/2013 2:55:39 PM(UTC)
Washer will not fill or wash (Washer Repair)
by rrobleto 11/1/2012 6:57:10 AM(UTC)
Whirlpool Top loading washer will not fill (Washer Repair)
by jeffjbrown 10/24/2012 6:43:26 PM(UTC)
by Annv 8/7/2012 6:18:45 AM(UTC)
washer will not fill with water on any cycle but still runs on spin cycle help (Washer Repair)
by Paul Linville 8/2/2012 4:29:08 PM(UTC)
Washer Will Not Fill (Washer Repair)
by powrrrplay 7/30/2012 4:00:40 PM(UTC)
