spartom
#1 Posted : Tuesday, July 3, 2012 5:11:47 PM(UTC)
spartom
Freezer reads 0 deg while fridge reads 45 deg. Fan in freezer does not run.
#2 Posted : Thursday, July 5, 2012 3:18:58 AM(UTC)
Replacement parts for Whirlpool ET1PHKXPQ08 REFRIGERATOR | AppliancePartsPros.com
Odds are that the evaporator fan is toast.
It should run whenever the compressor and it's fan are on.
To check measure the voltage across the fan.
If you get 120 volts and the fan does not run it is toast for sure.
spartom
#3 Posted : Thursday, July 5, 2012 10:45:11 AM(UTC)
spartom
Originally Posted by: denman Go to Quoted Post
I did check power to fan and had 120 volts so I ordered the evap fan motor. Thanks for help
Tom
spartom
#4 Posted : Sunday, July 8, 2012 3:49:54 AM(UTC)
spartom
Tom
Replaced evap fan motor and unit appears to be operating normally.:) What is the normal temp range of fridge and freezer?
#5 Posted : Sunday, July 8, 2012 5:03:46 AM(UTC)
Freezer should be 0 to 5 degrees F.
Fresh food should be close to 40 degrees F.
spartom
#6 Posted : Sunday, July 8, 2012 5:31:59 AM(UTC)
spartom
Thank you again for the information. Fridge is around 44 deg. and I suspect with time it may drop another deg. or two.
Tom
Freezer cold, Fridge Warm Kenmore 253.60082411. Model doesn't have timer (Refrigerator & Freezer Repair)
by jhmon 5/29/2020 12:20:04 AM(UTC)
Freezer cold, fridge warm Whirlpool (Refrigerator & Freezer Repair)
by Debma 1/25/2016 11:09:49 PM(UTC)
Freezer cold, Fridge warm (Refrigerator & Freezer Repair)
by mburke615 4/15/2013 11:39:06 AM(UTC)
freezer cold, fridge warm, damper closed tite (Refrigerator & Freezer Repair)
by thecac 7/11/2012 11:25:55 AM(UTC)
GE freezer cold, fridge warm (Refrigerator & Freezer Repair)
by dsandwich 7/1/2012 1:21:45 PM(UTC)
Freezer cold, fridge warm, unit constantly running (Refrigerator & Freezer Repair)
by mista_eng 5/30/2011 8:14:22 PM(UTC)
Freezer cold, fridge warm (Refrigerator & Freezer Repair)
by Sunshineoeff 9/8/2010 7:03:58 AM(UTC)
Freezer cold, fridge warm - please help !! (Refrigerator & Freezer Repair)
by aviator2010 9/25/2009 10:02:45 AM(UTC)
