Freezer reads 0 deg while fridge reads 45 deg. Fan in freezer does not run.
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  I did check power to fan and had 120 volts so I ordered the evap fan motor. Thanks for help Tom
Originally Posted by: spartom  I did check power to fan and had 120 volts so I ordered the evap fan motor. Thanks for help Tom Replaced evap fan motor and unit appears to be operating normally.:) What is the normal temp range of fridge and freezer?
Freezer should be 0 to 5 degrees F. Fresh food should be close to 40 degrees F. |
Originally Posted by: denman  Freezer should be 0 to 5 degrees F. Fresh food should be close to 40 degrees F. Thank you again for the information. Fridge is around 44 deg. and I suspect with time it may drop another deg. or two. Tom
Freezer cold, Fridge Warm Kenmore 253.60082411. Model doesn't have timer
(Refrigerator & Freezer Repair)
by jhmon
5/29/2020 12:20:04 AM(UTC)
Freezer cold, fridge warm Whirlpool
by Debma
1/25/2016 11:09:49 PM(UTC)
Freezer cold, Fridge warm
by mburke615
4/15/2013 11:39:06 AM(UTC)
freezer cold, fridge warm, damper closed tite
by thecac
7/11/2012 11:25:55 AM(UTC)
GE freezer cold, fridge warm
by dsandwich
7/1/2012 1:21:45 PM(UTC)
Freezer cold, fridge warm, unit constantly running
by mista_eng
5/30/2011 8:14:22 PM(UTC)
by Sunshineoeff
9/8/2010 7:03:58 AM(UTC)
Freezer cold, fridge warm - please help !!
by aviator2010
9/25/2009 10:02:45 AM(UTC)
