spartom
#1 Posted : 13 years ago
spartom
Freezer reads 0 deg while fridge reads 45 deg. Fan in freezer does not run.
#2 Posted : 13 years ago
Replacement parts for Whirlpool ET1PHKXPQ08 REFRIGERATOR | AppliancePartsPros.com
Odds are that the evaporator fan is toast.
It should run whenever the compressor and it's fan are on.
To check measure the voltage across the fan.
If you get 120 volts and the fan does not run it is toast for sure.
spartom
#3 Posted : 13 years ago
spartom
Originally Posted by: denman Go to Quoted Post
I did check power to fan and had 120 volts so I ordered the evap fan motor. Thanks for help
Tom
spartom
#4 Posted : 13 years ago
spartom
Tom
Replaced evap fan motor and unit appears to be operating normally.:) What is the normal temp range of fridge and freezer?
#5 Posted : 13 years ago
Freezer should be 0 to 5 degrees F.
Fresh food should be close to 40 degrees F.
spartom
#6 Posted : 13 years ago
spartom
Thank you again for the information. Fridge is around 44 deg. and I suspect with time it may drop another deg. or two.
Tom
Freezer cold, Fridge Warm Kenmore 253.60082411. Model doesn't have timer (Refrigerator & Freezer Repair)
by jhmon 5 years ago
Freezer cold, fridge warm Whirlpool (Refrigerator & Freezer Repair)
by Debma 9 years ago
Freezer cold, Fridge warm (Refrigerator & Freezer Repair)
by mburke615 12 years ago
freezer cold, fridge warm, damper closed tite (Refrigerator & Freezer Repair)
by thecac 13 years ago
GE freezer cold, fridge warm (Refrigerator & Freezer Repair)
by dsandwich 13 years ago
Freezer cold, fridge warm, unit constantly running (Refrigerator & Freezer Repair)
by mista_eng 14 years ago
Freezer cold, fridge warm (Refrigerator & Freezer Repair)
by Sunshineoeff 15 years ago
Freezer cold, fridge warm - please help !! (Refrigerator & Freezer Repair)
by aviator2010 16 years ago
