The dryer turns on and tumbles but produces no heat. The ignitor glows and stays hot but the burner never ignites. I have tested and have continuity on the thermal fuse and the high limit thermostat. There is no continuity on the thermistor. Is the thermistor defective? Thanks for any help. Bill
Hi Gene,
I checked the coils for continuity and they both have it. I suspect that I may have a bad flame sensor. The ignitor glows hot and just keeps glowing, but no ignition of the burner.
Bill
Hi Gene,
Bill
