BillMc
#1 Posted : Friday, September 4, 2009 12:28:44 PM(UTC)
BillMc
The dryer turns on and tumbles but produces no heat. The ignitor glows and stays hot but the burner never ignites. I have tested and have continuity on the thermal fuse and the high limit thermostat. There is no continuity on the thermistor. Is the thermistor defective? Thanks for any help. Bill
#2 Posted : Friday, September 4, 2009 2:31:31 PM(UTC)
Hi Bill,
The first failure suspect is a bad gas valve coils.
- The coil kit Part number: AP2150379
BillMc
#3 Posted : Friday, September 4, 2009 3:35:12 PM(UTC)
BillMc
Hi Gene,
I checked the coils for continuity and they both have it. I suspect that I may have a bad flame sensor. The ignitor glows hot and just keeps glowing, but no ignition of the burner.
Bill
BillMc
#4 Posted : Friday, September 4, 2009 3:37:36 PM(UTC)
BillMc
Hi Gene,
Bill
#5 Posted : Friday, September 4, 2009 3:43:30 PM(UTC)
If the igniter glows nonstop then the flame sensor is bad.
Presence of continuity does not prove the coils are good. They have to have specific resistance - http://forum.appliancepartspros...er-runs-but-no-heat.html.
Dryer will not heat (Dryer Repair)
by MByram 4/22/2018 8:36:12 PM(UTC)
Dryer Will Not Heat (Dryer Repair)
by coreyhall 3/6/2017 10:18:48 AM(UTC)
Dryer will not heat or turn off (Dryer Repair)
by jesus freak 1/17/2016 2:25:22 PM(UTC)
by rwebb 12/4/2015 9:44:48 AM(UTC)
Dryer will not heat and will not shut off (Dryer Repair)
by HMH1983 9/23/2015 6:44:16 PM(UTC)
Default Dryer will not heat, timer does not work (Dryer Repair)
by gotcoffee82 3/1/2015 7:37:21 PM(UTC)
Dryer will not heat up (Dryer Repair)
by kpholler 12/2/2014 3:42:57 PM(UTC)
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10/9/2014 8:16:39 PM(UTC)
Kenmore Dryer Will Not Heat After Replacing Everything (Dryer Repair)
by jlewis57 10/1/2014 12:28:50 PM(UTC)
Dryer will not heat and timer will not advance (Dryer Repair)
by MNJames 9/15/2014 2:46:05 PM(UTC)
Dryer Will Not Heat, But All Parts Test OK (Dryer Repair)
by kamera 9/6/2014 9:33:05 AM(UTC)
Roper dryer will not heat (new parts installed too) (Dryer Repair)
by xenomorphlv426 2/1/2014 8:49:03 AM(UTC)
GE harmony profile gas dryer will not heat (Dryer Repair)
by Thespiderman20 9/10/2013 5:44:45 PM(UTC)
Dryer will not heat. (Dryer Repair)
by modelshop8624 7/4/2013 1:24:12 PM(UTC)
Kenmore Dryer will not heat but the drum runs (Dryer Repair)
by asirota1 3/25/2013 8:33:52 AM(UTC)
