Hi, I am new here. :)Just ordered a new clock/timer and door gasket from Appliance Parts.com and I am looking for a description of how to install it. I read a blog on another site (I can't seem to find that site again)and I am pretty sure how to do it but I just need a little support. Also got a new door gasket and wondered how to get the ends in the holes. Can I just cram them in or do I need to remove the panel. Thanks
Originally Posted by: red belly  Hi, I am new here. :)Just ordered a new clock/timer and door gasket from Appliance Parts.com and I am looking for a description of how to install it. I read a blog on another site (I can't seem to find that site again)and I am pretty sure how to do it but I just need a little support. Also got a new door gasket and wondered how to get the ends in the holes. Can I just cram them in or do I need to remove the panel. Thanks You should be able to squeeze the metal retainers on the gasket and get them into the openings without taking the door apart. As far as the clock, you'll need to remove the screws holding the control panel in place, you should be able to see them when you open the oven door. The panel should pivot out at that point. Make sure you remove the power to the unit before doing that. After you have access to the back of the control I believe you'll find the rest to be self explanatory.
