Joined: 5/28/2024(UTC) Posts: 0  Location: Western Massachusetts
This 70s-era (I'm guessing) range came with the house. It's always put soot on pots and pans and had yellow flames. It's only now occurring to me that I can probably do something about that. But what? First I'll determine if it's even got LP orifices (LP is the gas we use). I'm guessing it does because it gets plenty hot enough. After that I'll adjust the fuel/air mixture at each burner. But... Is there a pressure regulator that should be checked? Especially if I decide it's never been converted to LP and so I put in new orifices. Or if it HAS been converted (orifice-wise) but not had the regulator tweaked accordingly (if needed). After all, if the orifices have been converted, why wasn't the mixture ever tweaked? Maybe they left the regulator alone, too? Finally, IF there is a regulator adjustment needed, how would I go about doing that? Hardwick model C G9626 W 79R (for what it's worth)  Just noticing that the label says on it to adjust the regulator when converting. D'oh! If I could only find a manual with those instructions... Edited by user Tuesday, May 28, 2024 3:13:13 PM(UTC)
| Reason: Not specified
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0  Location: TN Was thanked: 14 time(s) in 14 post(s)
DaveLab, based on the information provided, the valve orifice hoods would need to be checked to make sure they are tightened snugly without being overtightened.
