red belly
#1 Posted : Thursday, September 3, 2009 6:02:03 AM(UTC)
red belly
Hi, I am new here. :)Just ordered a new clock/timer and door gasket from Appliance Parts.com and I am looking for a description of how to install it. I read a blog on another site (I can't seem to find that site again)and I am pretty sure how to do it but I just need a little support. Also got a new door gasket and wondered how to get the ends in the holes. Can I just cram them in or do I need to remove the panel. Thanks
Frank / APP Team
#2 Posted : Thursday, September 3, 2009 7:11:23 AM(UTC)
Frank / APP Team
You should be able to squeeze the metal retainers on the gasket and get them into the openings without taking the door apart.
As far as the clock, you'll need to remove the screws holding the control panel in place, you should be able to see them when you open the oven door. The panel should pivot out at that point. Make sure you remove the power to the unit before doing that. After you have access to the back of the control I believe you'll find the rest to be self explanatory.
Recommend gas range single oven (General Talk)
by 007noob 6/10/2024 3:19:57 PM(UTC)
Old Hardwick Gas Range LP conversion and/or adjustment (Oven Repair (including Ranges and Cooktops))
by DaveLab 5/28/2024 2:53:48 PM(UTC)
Kitchenaid Oven range Superba kgsc308lss0 not heating up (Oven Repair (including Ranges and Cooktops))
by rattty 5/19/2024 6:51:16 PM(UTC)
Natural gas orifices GE range (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 5/12/2024 2:30:45 PM(UTC)
Samsung Range Overheating Oven (Oven Repair (including Ranges and Cooktops))
by ajerwin 5/6/2024 4:34:22 AM(UTC)
Ref - GE Profile Range Model No. PS950EF3ES (Oven Repair (including Ranges and Cooktops))
by JimBAgde 4/6/2024 11:11:04 AM(UTC)
GE range panel lights (Oven Repair (including Ranges and Cooktops))
by Guest 3/23/2024 8:44:57 AM(UTC)
whirlpool range GS395LEG (Oven Repair (including Ranges and Cooktops))
by Guest 3/18/2024 12:17:23 PM(UTC)
Kitchen Aid Electric Range Oven YKERS208XS1 (Oven Repair (including Ranges and Cooktops))
by Steph325 3/10/2024 12:00:38 PM(UTC)
Viking gas range oven troubleshooting (Oven Repair (including Ranges and Cooktops))
by MK_ 3/3/2024 10:10:13 AM(UTC)
KitchenAid Gar Range - Oven Intermittent Lighting (Oven Repair (including Ranges and Cooktops))
by JDinKTX 2/25/2024 5:05:21 AM(UTC)
Viking propane range #VGCC530-4B, oven/broiler dead, all other features working (Oven Repair (including Ranges and Cooktops))
by Andy Douglass 2/21/2024 2:06:07 PM(UTC)
Russell Range 6-burner available (Oven Repair (including Ranges and Cooktops))
by scott99 2/20/2024 4:40:34 PM(UTC)
Kitchenaid Gas Range KGRA806PSS00 (Oven Repair (including Ranges and Cooktops))
by bobr55 2/16/2024 1:31:09 PM(UTC)
GE range replacing a infinite switch but need the wiring diagram (Oven Repair (including Ranges and Cooktops))
by jlsalazar101 1/24/2024 2:49:12 PM(UTC)
