I just replaced the blower motor, now the motors run but the gas valves don't work. The ignitor glows the safety t stats are closed and if I take the wires off the flame sensor the ignitor will not heat up. The linear valve gets 6.6 volts dc calls for 12 volts dc the other 2 valves get no voltage at all. I am a licensed electrician and have used a multi meter to check the components listed above. I do have resistance on the coils for the valves therefore I believe that they are ok.
Press the Help button. On the Touch screen, select Troubleshooter. On the Touch screen, select the problem description from the list. You can use the arrows at the right of the screen to scroll up and down through the list of additional problems. On the Touch screen, select a possible cause for the problem and follow the on-screen instructions to find a solution. Here are the breakdown diagrams and Replacement parts for GE DPGT750GC1PL | AppliancePartsPros.comGene.
This did not help at this point I think that the power board may be bad.
