wample
#1 Posted : Monday, August 24, 2009 8:39:58 AM(UTC)
wample
I just replaced the blower motor, now the motors run but the gas valves don't work. The ignitor glows the safety t stats are closed and if I take the wires off the flame sensor the ignitor will not heat up. The linear valve gets 6.6 volts dc calls for 12 volts dc the other 2 valves get no voltage at all. I am a licensed electrician and have used a multi meter to check the components listed above. I do have resistance on the coils for the valves therefore I believe that they are ok.
#2 Posted : Monday, August 24, 2009 11:30:29 AM(UTC)
Press the Help button. On the Touch screen, select Troubleshooter. On the Touch screen, select the problem description from the list. You can use the arrows at the right of the screen to scroll up and down through the list of additional problems. On the Touch screen, select a possible cause for the problem and follow the on-screen instructions to find a solution.
Here are the breakdown diagrams and Replacement parts for GE DPGT750GC1PL | AppliancePartsPros.com
wample
#3 Posted : Monday, August 24, 2009 4:21:50 PM(UTC)
wample
This did not help at this point I think that the power board may be bad.
Knocking noise from my ge gas dryer. (Dryer Repair)
by Lougaal 2/16/2023 9:40:08 AM(UTC)
GE gas dryer rattling (Dryer Repair)
by johno1947 4/24/2017 4:11:51 PM(UTC)
GE gas dryer heats for a few minutes, then goes cold (Dryer Repair)
by swapped 9/24/2015 9:31:14 AM(UTC)
Weird, GE gas dryer not keep running (Dryer Repair)
by techlover 8/6/2015 8:14:16 AM(UTC)
GE Gas Dryer Igniter Glows but No Flame (Dryer Repair)
by kwillindy 5/4/2015 9:21:49 AM(UTC)
GE gas dryer timer will not advance on Easy Care feature (Dryer Repair)
by MrsG 1/23/2015 5:38:59 PM(UTC)
GE gas dryer on/off button (Dryer Repair)
by phillipj 1/10/2015 3:00:35 PM(UTC)
GE Gas dryer (Dryer Repair)
by cstellar 12/22/2014 10:46:32 AM(UTC)
GE Gas Dryer Error Code E01 & Stopped intermittently (Dryer Repair)
by bhurlbert 4/21/2013 5:43:49 PM(UTC)
GE gas dryer won't stay on (Dryer Repair)
by Bearjohnson 2/26/2013 10:36:11 PM(UTC)
ge gas dryer trips fuse after installing ignitor (Dryer Repair)
by lucyfoot 2/25/2013 3:19:07 PM(UTC)
GE gas dryer runs but no heat. (Dryer Repair)
by rroy58 11/19/2012 3:07:23 PM(UTC)
ge gas dryer no heat (Dryer Repair)
by mdelgiu1 11/7/2012 1:23:14 AM(UTC)
GE Gas Dryer - Drum Won't Turn / Locked Up (Dryer Repair)
by roma1625 10/31/2012 9:52:33 AM(UTC)
Ge gas dryer no heat (Dryer Repair)
by moby2000 10/25/2012 9:04:28 AM(UTC)
