jaydela
#1 Posted : Monday, August 10, 2009 2:59:34 AM(UTC)
jaydela
Help, I've replaced heating element, [FONT='Calibri','sans-serif']thermostat high limit 221 F and thermostat internal-bias and still no heat. Not sure if I tested continuity correctly, it's now reading 0 for the newly replaced parts? What else can be wrong?[FONT='Calibri','sans-serif'] :confused: [/FONT][/FONT]
sidfink43
#2 Posted : Wednesday, August 12, 2009 6:15:38 AM(UTC)
sidfink43
Hi Jay
Use your meter to check that you have 120v coming to each side of the connection block.
You should not get a zero reading on continuity checks, make sure you are using the right scale on the ohm meter. Check the thermal fuse, then check all of the other components.
Good luck
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
by chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
