Help, I've replaced heating element, [FONT='Calibri','sans-serif']thermostat high limit 221 F and thermostat internal-bias and still no heat. Not sure if I tested continuity correctly, it's now reading 0 for the newly replaced parts? What else can be wrong?[FONT='Calibri','sans-serif'] :confused: [/FONT][/FONT]
Hi Jay
Use your meter to check that you have 120v coming to each side of the connection block.
You should not get a zero reading on continuity checks, make sure you are using the right scale on the ohm meter. Check the thermal fuse, then check all of the other components.
Good luck
