dvokaty
#1 Posted : Friday, August 7, 2009 9:57:19 AM(UTC)
dvokaty
The compressor tries to start but kicks out. Very hot but when allowed to cool, still doesnt start. Assuming the compressor is bad, can one install a compressor kit without losing refrigerant?
magician59
#2 Posted : Friday, August 7, 2009 10:29:55 AM(UTC)
magician59
No. Inorder to replace the compressor, the refrigerant must be removed. Then after the new compressor is installed and the system is leak-tested, new refrigerant must be added.
HVACTECH1
#3 Posted : Saturday, August 8, 2009 8:55:23 AM(UTC)
HVACTECH1
Originally Posted by: magician59 Go to Quoted Post
No. Inorder to replace the compressor, the refrigerant must be removed. Then after the new compressor is installed and the system is leak-tested, new refrigerant must be added. Don't forget to pull a vacume on the system to get mosture and air out.
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
Kitchenaid KSRG25FKSS15 Refridg buzz/rattle on compressor start (Refrigerator & Freezer Repair)
by Guest 6/23/2024 8:35:15 AM(UTC)
True GDM-26-LD Display Fridge compressor issues (Refrigerator & Freezer Repair)
by KSlank76 6/22/2024 10:24:23 PM(UTC)
Frigidaire PLHS238ZCB1 Refigerator compressor issues. (Refrigerator & Freezer Repair)
by TonyMertz 5/18/2024 9:32:13 PM(UTC)
Compressor Start Device constantly needs replacing (Refrigerator & Freezer Repair)
by norsemen 3/11/2024 2:17:34 PM(UTC)
Compressor & condenser fan not running - low voltage, start relay ok (Refrigerator & Freezer Repair)
by Guest 1/17/2024 11:51:38 AM(UTC)
Amana compressor issues (Refrigerator & Freezer Repair)
by Guest 1/1/2024 12:42:43 PM(UTC)
refrigerator compressor clicking off (Refrigerator & Freezer Repair)
by rleescott 12/22/2023 4:57:43 AM(UTC)
LG Refrigerator not cooling; compressor clicking. (Refrigerator & Freezer Repair)
Belarus pmrowley 11/8/2023 7:07:53 AM(UTC)
Refrigerator inverter compressor not starting (Refrigerator & Freezer Repair)
by Guest 11/1/2023 4:24:39 PM(UTC)
Need help with cut in cut out Old McQuay freezer w/Hupp compressor (Refrigerator & Freezer Repair)
by Deserttoad 5/5/2023 2:39:37 PM(UTC)
Not defrosting and motor/compressor running constantly (Refrigerator & Freezer Repair)
by egizzi 3/23/2023 7:05:21 PM(UTC)
compressor start relay question (Refrigerator & Freezer Repair)
by Guest 10/16/2022 2:45:39 AM(UTC)
Noisy Commercial Refigerator Compressor (Refrigerator & Freezer Repair)
by djsource 9/18/2022 12:24:54 PM(UTC)
Embraco EMI30HER Compressor - is it toast? (Refrigerator & Freezer Repair)
by Guest 5/10/2022 4:59:08 AM(UTC)
