TREFFJ
#1 Posted: : Tuesday, January 8, 2008 3:24:18 PM(UTC)
TREFFJ
Left front ring stays maximum heat when truned on. Cannot adjust to a lower setting. This element has a simmer button which will cool the ring off. Is this a bad control knob?
#2 Posted : Wednesday, January 9, 2008 12:22:42 PM(UTC)
Most likely the problem is a bad infinite switch for this burner.
- The part number for the infinite switch is AP2124692
Good luck.
TREFFJ
#3 Posted : Saturday, January 12, 2008 12:58:24 PM(UTC)
TREFFJ
Gene, received the part, replaced it and works lake a champ! thanks
TREFFJ
#4 Posted : Saturday, January 12, 2008 1:00:46 PM(UTC)
TREFFJ
Suggested part received and replaced. Works fine..thanks
#5 Posted : Tuesday, January 15, 2008 10:35:32 AM(UTC)
I'm glad you were able to fix it.
Kitchen Aid Electric Range Oven YKERS208XS1 (Oven Repair (including Ranges and Cooktops))
by Steph325 3/10/2024 12:00:38 PM(UTC)
Whirlpool Electric Range Cooktop Will not Heat (Oven Repair (including Ranges and Cooktops))
by mraupie17 9/2/2023 9:50:45 AM(UTC)
Problem with Whirlpool electric range (won't heat properly anymore) (Oven Repair (including Ranges and Cooktops))
by phillydee 4/20/2023 6:10:35 AM(UTC)
Whirlpool electric range GR563LXSS (Oven Repair (including Ranges and Cooktops))
by longtimealaskan 3/6/2023 9:47:00 PM(UTC)
Samsung electric range bake and broil do not work (Oven Repair (including Ranges and Cooktops))
by Guest 12/20/2022 2:07:19 PM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Westinghouse Electric Range Model KF341R (Appliance Parts)
by GEman 5/28/2022 9:09:03 AM(UTC)
GE electric range - nothing works but the clock (Oven Repair (including Ranges and Cooktops))
by Jelltronic 5/15/2022 6:28:03 AM(UTC)
Frigidaire LGEF3043KFM Electric Range Uneven Heat (Oven Repair (including Ranges and Cooktops))
by Asweateria 2/27/2022 9:32:41 PM(UTC)
Samsung electric range (Oven Repair (including Ranges and Cooktops))
by MELLIOTT 2/8/2022 6:38:17 AM(UTC)
LG Electric Range Overheating (Oven Repair (including Ranges and Cooktops))
by jenvee 1/25/2022 7:20:52 AM(UTC)
kenmore electric range 79097459802 (Oven Repair (including Ranges and Cooktops))
by Melissadimas 1/9/2022 9:07:08 PM(UTC)
replacing latch, door on Kitchen Aid electric range series II (Oven Repair (including Ranges and Cooktops))
by WSCHUMANN 7/12/2021 6:02:36 AM(UTC)
GE Electric Range Keeps turning off (Oven Repair (including Ranges and Cooktops))
by Guest 5/7/2021 9:58:17 AM(UTC)
REPLACE OVEN DOOR OUTER GLASS FRIDGAIR ELECTRIC RANGE MODELFEF357BBA (Oven Repair (including Ranges and Cooktops))
by Guest 5/3/2021 12:14:15 PM(UTC)
