Jeremy
#1 Posted : Friday, August 3, 2007 10:24:00 AM(UTC)
Jeremy
I would like to know how to take the dryer pulley tensioner (#AP2911909) which is supposed to fit Roper, Whirlpool, etc. apart to put the drum belt into.
Jeremy
jdman
#2 Posted : Friday, August 3, 2007 10:26:21 AM(UTC)
jdman
I don't think you have to take it off. Can't you pull to relase the tension?
ApplianceJunk
#3 Posted : Friday, August 3, 2007 4:18:59 PM(UTC)
ApplianceJunk
Just push the top of the idler towards the right side of the dryer.
Then you will be able to slip the belt off of the motor pulley.
Dryer Idler Pulley
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 11/22/2020 12:41:02 PM(UTC)
Idler pulley on maytag dryer (Dryer Repair)
by TommieS541 2/16/2016 11:55:28 PM(UTC)
Kenmore HE5 screeching sound...belt replacement/idler pulley or both? (Dryer Repair)
by kaikapoo 9/7/2013 5:56:19 PM(UTC)
Idler Pulley Tension Spring Placement Diagram (Dryer Repair)
by Charlie6969 8/16/2012 9:11:24 AM(UTC)
Question re: Washer Idler pulley wheel (Washer Repair)
by Rene' 4/8/2012 10:26:10 AM(UTC)
Idler Pulley orientation (Dryer Repair)
by Muleskinner 9/23/2011 5:50:09 PM(UTC)
tension idler pulley (Washer Repair)
by reorob 8/1/2011 12:55:06 PM(UTC)
Idler Pulley & Idler Bracket Lube ? (Dryer Repair)
by mr.c40 4/7/2011 5:30:51 AM(UTC)
Problem w/idler pulley (Dryer Repair)
by Racingtina 3/4/2011 9:57:26 AM(UTC)
how do i replace the idler pulley and belt on my electric dryer? (Dryer Repair)
by keribell 11/27/2010 5:45:35 PM(UTC)
Dryer Idler Pulley (Dryer Repair)
by Mommaski 8/12/2010 7:12:21 AM(UTC)
idler pulley spring placement (Dryer Repair)
by mikeniel 2/3/2010 5:11:33 PM(UTC)
Idler pulley and dryer belt problem (Dryer Repair)
Belarus mel113 12/10/2009 10:54:59 AM(UTC)
maytag dryer - idler pulley/drum rollers lubrication (Dryer Repair)
by patentable 10/31/2009 12:45:27 PM(UTC)
