I just bought a belt to replace my broken one on a maytag neptune mde9700ayw, after taking everything apart I saw that my idler pulley roller wheel would not spin freely and I even had trouble spinning it by hand, also half of it has a hole in it and the other does not. I'm wondering if this is normal for it to have a hole? I have a picture attached of what the roller looks like. Thanks in advance. TommieS541 attached the following image(s):
change the pulley but make sure the shaft is not worn in any way. clean and lubricate and you should be ok. Have seen this several times.
