Old Wino
#1 Posted : 13 years ago
Old Wino
Refrigerator is currently around 32 degrees, even tho setting is at lowest (sun icon). Freezer is below zero, and is also set at lowest) . The freezer was accidentally turned off for part of a day last week. I also did clean the very dirty coils yesterday and also the back grate. What else should I try?
#2 Posted : 13 years ago
Replacement parts for Amana TR18V2E REF - TOP MOUNT | AppliancePartsPros.com
Is the compressor cycling normally or is it on all the time?
Measure the freezer temperature. It should be between 0 and -5 degrees F.
If lower then your main thermostat (Item 62 in Section 5) probably needs replacing.
if the freezer temperature is OK then check the damper (Item 42 in Section 5), to see if it opens/closes depending on it's setting.
Check that the door can open/close, could be that due to the unit being turned off some water got into it and froze the door open.
Unfortunately it is obsolete.
Old Wino
#3 Posted : 13 years ago
Old Wino
Originally Posted by: denman Go to Quoted Post
No, door opens, closes oK. Seems to me freezer was running closer to ten below. A local outfit said something about setting the freezer colder so less cold gets circulated to fridge. Been less than 24 hours, but seemed to have no effect. He thought baffle might need replacing. Does that sound right?
#4 Posted : 13 years ago
I would get the freezer to the recommended temperature and then see what happens.
The 24 hours makes sense to me as the food/ice in the freezer will take quite a while to come up to temperature.
Lowering the temperature does not make sense as it will cause the compressor to run more and I believe your evaporator fan runs whenever the compressor runs so there is more air circulation.
Note:I may be out to lunch on this.
I do not know if I screwed up but I meant the door/flapper on the damper assembly.
It should close on the warmest fresh food setting.
Top freezer refrigerator too cold. (Refrigerator & Freezer Repair)
by yaworski 4 years ago
Samsung Refrigerator too cold (Refrigerator & Freezer Repair)
by jim.grove1 5 years ago
Kitchen Aid Refrigerator Too Cold (Refrigerator & Freezer Repair)
by txh123 8 years ago
Frigidaire S x S refrigerator too cold (Refrigerator & Freezer Repair)
by APPLIANCEDUDE1972 10 years ago
GE refrigerator too cold, unstable temp cycle (Refrigerator & Freezer Repair)
by James2000 11 years ago
Kenmore side by side refrigerator too cold (Refrigerator & Freezer Repair)
by Fisheyeii 11 years ago
Refrigerator too cold, Freezer melting and refreezing (Refrigerator & Freezer Repair)
by ejnelson24 12 years ago
KitchenAid Refrigerator Too Cold (Refrigerator & Freezer Repair)
by famcar 12 years ago
Refrigerator too cold and uncontrolable (Refrigerator & Freezer Repair)
by nailerdog 13 years ago
Refrigerator Too Cold Vegetables Freezing (Refrigerator & Freezer Repair)
by olgapico 13 years ago
by lgray215 13 years ago
by jimmybass 14 years ago
by TaniaH 14 years ago
by Paul Sobus 14 years ago
Refrigerator too cold (Dishwasher Repair)
by DEEDEEGOGO 14 years ago
