DEEDEEGOGO
#1 Posted : Monday, February 21, 2011 4:15:39 PM(UTC)
DEEDEEGOGO
My refrigerator is too cold 30 degrees! Any adjustment on the temp control has no effect. I spoke to a local appliance shop & they thought it was the therostat not working properly.Could this be true and if yes, Is the thermostat something I could change and where is it located ?
Jeff / APP Team
#2 Posted : Tuesday, February 22, 2011 4:48:11 AM(UTC)
Jeff / APP Team
Well we need to test the thermistor on this unit. If the thermistor is ok, then you have a diffuser problem. The thermistor and diffuser are located in the upper left side of the refrigerator. Here are the readings for the thermistor. You will need a multi-meter to test it.
Temperature Resistance
77°F..................10,000 ohms
36°F..................29,500 ohms
0°F....................86,300 ohms
Here are the part numbers for both parts. Hope this helps.
Part number: AP3745265
Top freezer refrigerator too cold. (Refrigerator & Freezer Repair)
by yaworski 2/15/2021 10:38:29 AM(UTC)
Samsung Refrigerator too cold (Refrigerator & Freezer Repair)
by jim.grove1 1/30/2020 10:26:16 AM(UTC)
Kitchen Aid Refrigerator Too Cold (Refrigerator & Freezer Repair)
by txh123 10/26/2016 5:27:11 PM(UTC)
Frigidaire S x S refrigerator too cold (Refrigerator & Freezer Repair)
by APPLIANCEDUDE1972 12/11/2014 6:27:01 PM(UTC)
GE refrigerator too cold, unstable temp cycle (Refrigerator & Freezer Repair)
by James2000 5/23/2014 8:15:56 AM(UTC)
Kenmore side by side refrigerator too cold (Refrigerator & Freezer Repair)
by Fisheyeii 11/16/2013 5:36:27 AM(UTC)
Refrigerator too cold, Freezer melting and refreezing (Refrigerator & Freezer Repair)
by ejnelson24 2/20/2013 3:48:45 PM(UTC)
KitchenAid Refrigerator Too Cold (Refrigerator & Freezer Repair)
by famcar 12/21/2012 5:41:32 PM(UTC)
Refrigerator too cold and uncontrolable (Refrigerator & Freezer Repair)
by nailerdog 3/25/2012 7:57:15 AM(UTC)
by Old Wino 1/19/2012 7:52:56 AM(UTC)
Refrigerator Too Cold Vegetables Freezing (Refrigerator & Freezer Repair)
by olgapico 11/15/2011 7:43:20 AM(UTC)
by lgray215 10/12/2011 4:08:57 PM(UTC)
by jimmybass 9/16/2011 12:41:24 PM(UTC)
by TaniaH 4/1/2011 7:52:26 AM(UTC)
by Paul Sobus 3/9/2011 6:22:01 AM(UTC)
