tomhickey
#1 Posted : Sunday, December 23, 2007 7:32:10 AM(UTC)
tomhickey
dryer will tumble but won't heat. I've checked continuity at all thermal fuses, outlet supply, blower thermal , safety thermos and they all test good. Also tested the timer and heat switches and they appear good. So I finally was able to test the leads on the heating element. (no continuity) Bingo! Next problem is how do I get element out ? Having a hard time getting the drum out. I have removed the drum belt but am having a problem lifting it out do to catching on the front drum sliders...
TechnicianBrian
#2 Posted : Sunday, December 23, 2007 9:41:30 AM(UTC)
TechnicianBrian
You must take the front panel off and slide the drum out the front. The back of the drum has a bearing assembly that will need to be lifted up about an inch before it can be removed. Look for screws and clips holding the front panel on. Once the drum is out, the element will be on the back bulkhead.
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
by chash 8/6/2015 9:12:57 AM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
