I have a GE front load washer that will not enter test mode. The real issue is that all the lights (start/pause) etc are blinking, but I cannot start the machine. I can change the cycle from Whites to colours etc but that it is the only button that works. Can't change anything else (i.e. eash temperature) and machine won't start. When I poer off and poer back on it turns straight back on into speed wash so I cannot enter test mode as it is not blank. Please help.
If the machine is less than one year old you should still have factory warranty and they should fix it.
If for some reason you no longer have factory warranty, post the model number (and tell us why) and let's see if we can help you.
Try to get this as a warranty repair because you are probably looking at replacing an expensive control unit.
