empresskaya
#1 Posted : Tuesday, June 9, 2009 1:27:49 PM(UTC)
empresskaya
I have a GE front load washer that will not enter test mode. The real issue is that all the lights (start/pause) etc are blinking, but I cannot start the machine. I can change the cycle from Whites to colours etc but that it is the only button that works. Can't change anything else (i.e. eash temperature) and machine won't start. When I poer off and poer back on it turns straight back on into speed wash so I cannot enter test mode as it is not blank. Please help.
sidfink43
#2 Posted : Wednesday, June 10, 2009 11:34:26 AM(UTC)
sidfink43
If the machine is less than one year old you should still have factory warranty and they should fix it.
If for some reason you no longer have factory warranty, post the model number (and tell us why) and let's see if we can help you.
Try to get this as a warranty repair because you are probably looking at replacing an expensive control unit.
GE front load washer issues (Washer Repair)
by poncho-mike 6/24/2020 11:06:01 AM(UTC)
GE Front Load Washer Control Board issues (Washer Repair)
by Deb B 5/31/2020 6:50:55 PM(UTC)
Ge front load washer no power even after reset attempts (Washer Repair)
by Mark867 3/5/2018 10:15:30 AM(UTC)
GE front load washer control panel not right (Washer Repair)
by dsmines 9/16/2015 12:11:22 PM(UTC)
GE front load washer will not drain (Washer Repair)
by Sandmann01 6/22/2015 1:24:04 AM(UTC)
GE Front Load Washer won't spin (Washer Repair)
by eyeroller 8/24/2014 10:24:11 AM(UTC)
My GE front load washer is not working (Washer Repair)
by Frogg7 6/10/2014 8:19:13 PM(UTC)
GE Front Load Washer Fill (Washer Repair)
by ted.godwinstremler 4/1/2014 4:31:10 PM(UTC)
GE Front Load washer won't drain or spin (Washer Repair)
by rmgaris 2/8/2014 8:15:28 PM(UTC)
GE Front Load Washer Not Agitating or Spinning (Washer Repair)
by mghump 12/16/2013 6:13:15 AM(UTC)
GE Front load washer leaks on rinse cycle fill (Washer Repair)
by damadczar 10/21/2013 3:26:51 PM(UTC)
GE front load Washer: Wont complete cycle (Washer Repair)
by Kmcelhinney 10/5/2013 1:52:14 PM(UTC)
GE Front load washer Fails - error E46 (Dishwasher Repair)
by darekatra 7/30/2013 6:28:32 PM(UTC)
GE Front Load Washer (Washer Repair)
by GHerm 7/3/2013 5:50:16 PM(UTC)
GE front load washer not spinning on fast cycle (Washer Repair)
by Sonja L 4/8/2013 6:16:35 PM(UTC)
