:( Washer was working fine,but the next day it would not fill. All other cycles work fine just no water. it started out it would fill on small load but not on large load,now it will not fill at all. any ideas what I should look for? Thanks in advance!
The first thing I would do is check the coils on the water inlet valve and power to the water inlet valve.
In order to provide the most accurate advise I need the complete model number of the washer.
Hi Gene, Thanks for the reply. Here is the model number ( RAB4132HQO ) And thanks again, George
George Did you check the coils and the power to the coils? - Here are the break down diagrams for the Roper washer Model RAB4132HQ0 to help you locate the parts. Gene.
