Replacement parts for MAYTAG LDE412 | AppliancePartsPros.comFirst switch the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. The heater requires 240 volts while the motor only uses 120 so depending which side drops out you can get the symptoms you see. Better yet check it at the plug with a meter for 240 volts.
Next check the heater then the thermostats.
I cannot find a thermal fuse in this unit which seems strange but cannot find a wiring diagram for this machine. Check in the control console for the wiring diagram it will help with trouble shooting.
Be sure to unplug the unit when working on it.
Here is a good site with basic dryer repair help.
http://www.applianceaid.com/dryers.html
