deec
#1 Posted : Monday, May 18, 2009 4:48:12 PM(UTC)
deec
Dryer does not heat. Nothing else seems to be wrong. How do I know what to look for first? Elements? Thermostat? Any suggestions? Thanks!
#2 Posted : Tuesday, May 19, 2009 3:33:42 AM(UTC)
Replacement parts for MAYTAG LDE412 | AppliancePartsPros.com
First switch the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. The heater requires 240 volts while the motor only uses 120 so depending which side drops out you can get the symptoms you see. Better yet check it at the plug with a meter for 240 volts.
Next check the heater then the thermostats.
I cannot find a thermal fuse in this unit which seems strange but cannot find a wiring diagram for this machine. Check in the control console for the wiring diagram it will help with trouble shooting.
Be sure to unplug the unit when working on it.
Here is a good site with basic dryer repair help.
http://www.applianceaid.com/dryers.html
Maytag Dryer shutting off after 2 minutes (Dryer Repair)
by Guest 11/9/2023 4:45:11 AM(UTC)
maytag dryer MEDC200XW1 (Dryer Repair)
by patnok 9/4/2023 8:02:13 AM(UTC)
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
Maytag Dryer MGD7230HW2 LP CONVERSION HELP!! (Dryer Repair)
by prodigey 10/14/2022 3:54:00 AM(UTC)
Maytag dryer (Mode MEDC300XW1) not starting, but runs only in Wrinkle Prevent cycle. (Dryer Repair)
by Guest 7/28/2022 6:31:22 PM(UTC)
Maytag dryer won't stop on timed dry (Dryer Repair)
by eaglemtn 11/11/2021 5:35:16 PM(UTC)
Maytag Dryer Slow to Spin after parts replacement (Dryer Repair)
by steelwindmachine 8/18/2021 5:58:15 AM(UTC)
Maytag Dryer not drying. Flame shuts off after 20-30 seconds (Dryer Repair)
by jbschwartz 6/27/2021 4:54:19 PM(UTC)
Maytag dryer MDE9316ATA (Dryer Repair)
by Guest 5/1/2021 3:45:42 PM(UTC)
Maytag Dryer (Bravos) (Dryer Repair)
by Kap61 3/29/2021 4:03:51 PM(UTC)
Maytag Dryer *usually* won't heat (Dryer Repair)
by ab52 6/12/2020 12:20:59 PM(UTC)
Maytag Dryer Starts But No Heat (Dryer Repair)
by boonie785 6/1/2020 3:32:33 PM(UTC)
Maytag dryer stops early (Dryer Repair)
by J-fixtit 5/28/2020 6:59:15 PM(UTC)
Maytag dryer dont start (Dryer Repair)
by jzemer 5/16/2020 5:58:30 PM(UTC)
MAYTAG dryer loud squealing/squeaking (Dryer Repair)
by joenobodyyet 3/24/2020 1:27:25 PM(UTC)
