kmoore77
#1 Posted : Friday, December 7, 2007 10:55:24 AM(UTC)
kmoore77
my washer filled up and will not do anything else. What is wrong??
#2 Posted : Friday, December 7, 2007 3:39:23 PM(UTC)
The first thing I would check is the lid switch.
jjoneness
#3 Posted : Friday, December 21, 2007 5:47:43 PM(UTC)
jjoneness
take the hoses off the water pump and check inside for damage or see if something is stuck in the pump. Is the timer running?
Ge dishwasher will not drain (Dishwasher Repair)
by Handyman924 2/24/2017 8:05:27 PM(UTC)
maytag washer will not drain water (Washer Repair)
by mathy10544 12/13/2015 8:54:09 PM(UTC)
GE front load washer will not drain (Washer Repair)
by Sandmann01 6/22/2015 1:24:04 AM(UTC)
Washer will not drain (Washer Repair)
by Artnlp 5/3/2015 7:34:59 AM(UTC)
Washer will not drain in Normal cycle (Washer Repair)
by rober luck 4/20/2015 9:10:47 AM(UTC)
by charles140 10/10/2014 8:21:01 AM(UTC)
by hurler72 11/25/2013 10:59:35 AM(UTC)
topload washer will not drain or spin (Washer Repair)
by olac757@gmail.com 8/9/2013 9:08:21 PM(UTC)
Whirlpool dishwasher will not drain (Dishwasher Repair)
by PeterZ 8/6/2013 7:21:51 PM(UTC)
Washer will not drain or spin (Washer Repair)
by Fixit Dad 5/23/2013 4:26:49 PM(UTC)
by PepperVal 5/16/2013 8:36:29 AM(UTC)
Whirlpool Washer will not drain unless open and close lid (Washer Repair)
by twhistle 2/28/2013 8:16:58 AM(UTC)
Washer will not drain or spin, new pump and lid switch (Washer Repair)
by tangerine30680 1/26/2013 12:42:38 PM(UTC)
I replaced lid switch, still washer will not drain or spin (Washer Repair)
by dnschrstn 11/12/2012 12:39:16 PM(UTC)
washer will not drain before the spin cycle (Washer Repair)
by tondot 11/11/2012 5:32:56 PM(UTC)
