The Machine Just hums when it is supposed to drain. The machine is all closed in. Where do you open the machine to work on it?
The Machine Just hums when it is supposed to drain. The machine is all closed in. Where do you open the machine to work on it:confused: If you could give me a Hand I would be very thankful :)
Originally Posted by: sfcdlj  The Machine Just hums when it is supposed to drain. The machine is all closed in. Where do you open the machine to work on it:confused: Do I open the front:confused: Or the bottom:confused: I don't see any Clips or fasteners that I can take off to open the washer up to work on it. If you could give me a Hand I would be very thankful :) :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek:
:eek: Originally Posted by: sfcdlj  The Machine Just hums when it is supposed to drain. The machine is all closed in. Where do you open the machine to work on it:confused: If you could give me a Hand I would be very thankful :) :o :o :o :o :o :o :o :o :o :o
GE Washer and it will not drain. and how do you open the case to work on the washer?
Slide a putty knife very carefully between the front and top panels at each end and you should pop the clips that hold the front panel to the cabinet.
You will then see the pump on the right hand side, and you should be able to trouble shoot the problem. Most likely you will need a new pump, but be sure to check the entire discharge line for an obstruction first!
Good luck and let us know how it turns out.
