sfcdlj
#1 Posted : Monday, May 4, 2009 6:21:35 AM(UTC)
sfcdlj
The Machine Just hums when it is supposed to drain. The machine is all closed in. Where do you open the machine to work on it?
sfcdlj
#2 Posted : Monday, May 4, 2009 6:27:10 AM(UTC)
sfcdlj
The Machine Just hums when it is supposed to drain. The machine is all closed in. Where do you open the machine to work on it:confused: If you could give me a Hand I would be very thankful :)
sfcdlj
#3 Posted : Monday, May 4, 2009 6:34:22 AM(UTC)
sfcdlj
Originally Posted by: sfcdlj Go to Quoted Post
The Machine Just hums when it is supposed to drain. The machine is all closed in. Where do you open the machine to work on it:confused: Do I open the front:confused: Or the bottom:confused: I don't see any Clips or fasteners that I can take off to open the washer up to work on it. If you could give me a Hand I would be very thankful :)
:eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek:
sfcdlj
#4 Posted : Monday, May 4, 2009 6:35:24 AM(UTC)
sfcdlj
:eek:
:o :o :o :o :o :o :o :o :o :o
sfcdlj
#5 Posted : Monday, May 4, 2009 6:42:51 AM(UTC)
sfcdlj
GE Washer and it will not drain. and how do you open the case to work on the washer?
sidfink43
#6 Posted : Monday, May 4, 2009 9:31:57 AM(UTC)
sidfink43
Slide a putty knife very carefully between the front and top panels at each end and you should pop the clips that hold the front panel to the cabinet.
You will then see the pump on the right hand side, and you should be able to trouble shoot the problem. Most likely you will need a new pump, but be sure to check the entire discharge line for an obstruction first!
Good luck and let us know how it turns out.
Will not drain on spin cycle (Washer Repair)
by Guest 8/7/2022 8:04:16 AM(UTC)
Whirlpool will not drain or cycle. No Obstructions. What next?? (Dishwasher Repair)
by RyGuy73 3/2/2020 6:29:56 PM(UTC)
Kenmore Model 665.13269K110 will not drain (Dishwasher Repair)
by LoserKorn 4/14/2019 1:21:36 PM(UTC)
Ge dishwasher will not drain (Dishwasher Repair)
by Handyman924 2/24/2017 8:05:27 PM(UTC)
Samsung Front Loader will not drain (Washer Repair)
by orangecrush 4/18/2016 6:32:48 PM(UTC)
maytag washer will not drain water (Washer Repair)
by mathy10544 12/13/2015 8:54:09 PM(UTC)
GE front load washer will not drain (Washer Repair)
by Sandmann01 6/22/2015 1:24:04 AM(UTC)
Washer will not drain (Washer Repair)
by Artnlp 5/3/2015 7:34:59 AM(UTC)
Washer will not drain in Normal cycle (Washer Repair)
by rober luck 4/20/2015 9:10:47 AM(UTC)
Whirlpool stops after wash cycle will not drain or spin (Washer Repair)
by JF2015 1/4/2015 7:19:52 AM(UTC)
by charles140 10/10/2014 8:21:01 AM(UTC)
maytag will not drain (Washer Repair)
by john rodriguez 7/15/2014 8:28:54 PM(UTC)
Maytag atlantis will not drain or spin (Washer Repair)
by Militoni 7/12/2014 3:34:57 AM(UTC)
by hurler72 11/25/2013 10:59:35 AM(UTC)
Whirlpool QPII not bringing in water, also will not drain (Dishwasher Repair)
by hawkeye680 11/2/2013 9:13:43 AM(UTC)
