szeus2
#1 Posted : Monday, April 6, 2009 5:36:30 AM(UTC)
szeus2
my kenmore electric range when i go to use the bake on the oven the element at the bottom does not get hot all the time what part is bad is it the element please let me know thanks david
#2 Posted : Monday, April 6, 2009 4:57:30 PM(UTC)
The model number you posted is incomplete. Verify and repost it.
szeus2
#3 Posted : Wednesday, April 8, 2009 6:32:08 AM(UTC)
szeus2
hi gene my kenmore electric range model # 790.95889302 and the serial # is vf40944454
#4 Posted : Wednesday, April 8, 2009 2:28:18 PM(UTC)
Hi David,
Pull the range out of the wall and remove the back cover. Remove the wires from the Bake heating element and check the heating element for continuity.
If it's open then replace the Bake heating element.
If there is nothing wrong and the wires for this element are good then replace the Electronic Oven Control (aka a clock).
- The part number for the Bake element is AP2126365
- The part number for the clock is AP3561834
glowski
#5 Posted : Tuesday, April 28, 2009 3:43:34 PM(UTC)
glowski
I have the same problem with a Kenmore Electric Range model number 911.9398710; serial # 7L70345, it will not heat after going thru the cleaning cycle. What part number(s) do I need?
#6 Posted : Wednesday, April 29, 2009 4:54:24 PM(UTC)
Do both Broil and Bake do not heat?
glowski
#7 Posted : Thursday, April 30, 2009 6:21:05 PM(UTC)
glowski
The broiler does work. There is an ON indicator that comes on when the Broiler
is activated that also comes on when the self-cleaning is taking place. That is probably normal. Now that ON light also comes on when I try to turn on the oven, but the oven does not heat.
thanks.
#8 Posted : Saturday, May 2, 2009 1:59:50 AM(UTC)
Pull the range out of the wall. Remove the rear cover and check the wires to the Bake heating element. Remove the wires from the Bake element terminals and check the element for continuity. Replace the element if it's open.
If the element is good then replace the control board.
- The part number for the Bake element is AP2030968
- The part number for the control board is AP2022868
Kitchen Aid Electric Range Oven YKERS208XS1 (Oven Repair (including Ranges and Cooktops))
by Steph325 3/10/2024 12:00:38 PM(UTC)
Whirlpool Electric Range Cooktop Will not Heat (Oven Repair (including Ranges and Cooktops))
by mraupie17 9/2/2023 9:50:45 AM(UTC)
Problem with Whirlpool electric range (won't heat properly anymore) (Oven Repair (including Ranges and Cooktops))
by phillydee 4/20/2023 6:10:35 AM(UTC)
Whirlpool electric range GR563LXSS (Oven Repair (including Ranges and Cooktops))
by longtimealaskan 3/6/2023 9:47:00 PM(UTC)
Samsung electric range bake and broil do not work (Oven Repair (including Ranges and Cooktops))
by Guest 12/20/2022 2:07:19 PM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Westinghouse Electric Range Model KF341R (Appliance Parts)
by GEman 5/28/2022 9:09:03 AM(UTC)
GE electric range - nothing works but the clock (Oven Repair (including Ranges and Cooktops))
by Jelltronic 5/15/2022 6:28:03 AM(UTC)
Frigidaire LGEF3043KFM Electric Range Uneven Heat (Oven Repair (including Ranges and Cooktops))
by Asweateria 2/27/2022 9:32:41 PM(UTC)
Samsung electric range (Oven Repair (including Ranges and Cooktops))
by MELLIOTT 2/8/2022 6:38:17 AM(UTC)
LG Electric Range Overheating (Oven Repair (including Ranges and Cooktops))
by jenvee 1/25/2022 7:20:52 AM(UTC)
kenmore electric range 79097459802 (Oven Repair (including Ranges and Cooktops))
by Melissadimas 1/9/2022 9:07:08 PM(UTC)
replacing latch, door on Kitchen Aid electric range series II (Oven Repair (including Ranges and Cooktops))
by WSCHUMANN 7/12/2021 6:02:36 AM(UTC)
GE Electric Range Keeps turning off (Oven Repair (including Ranges and Cooktops))
by Guest 5/7/2021 9:58:17 AM(UTC)
REPLACE OVEN DOOR OUTER GLASS FRIDGAIR ELECTRIC RANGE MODELFEF357BBA (Oven Repair (including Ranges and Cooktops))
by Guest 5/3/2021 12:14:15 PM(UTC)
