My freezer is too cold. I checked it a couple of days ago in a quest to find out why my electric bill has gone crazy. It was -20, so I reset the control. Next day it was 0 and I figured all was well. Tonight, it's -20 again. I opened the door and set the control to the lowest setting. The thermometer was at 0, a few minutes later it at -20 again. The freezer seems to be running even though the temperature is much too cold. I'm guessing bad thermostat, but I don't know much about freezers. There is no ice build-up inside and the seal appears good (it vacuums when closed). Also, I tried to clean the coils but can't find them. Are they behind a panel somewhere? One more symtom, may or may not be something. For months I've heard a buzzing at times, and it would stop if I tapped the side of the freezer. Now I'm not hearing that at all.
It’s possible that it is running all the time, which would mean that the cold control is bad. –20 for a deep freezer is not bad but frost-free freezers usually won’t get that low. I don’t believe this will cause your high electric bill. Freezers cost about $5 a month in electricity when operating properly and they run about 80% of the time when operating properly. So if it were running 100% of the time, it would only be a 20% increase and your electric bill would only go up about $1.00 a month. These numbers will vary with each model. Hope this helps!! Appliance Repair Guide For All Major Home Appliances [FONT='Times New Roman']Oh and there are no coils to clean on most freezers. [/FONT]
old maytag mtb1895 freezer too cold
(Refrigerator & Freezer Repair)
by Guest
1/26/2022 8:49:08 PM(UTC)
Frigidaire FFHS2611PF, freezer too cold
by rleary78@gmail.com
1/26/2021 8:04:49 AM(UTC)
Compressor loud, runs constantly. Fridge/freezer too cold
by Plasticspaceman
4/15/2020 8:23:37 PM(UTC)
Freezer too cold, Ice build up causing leak
by Sgibb16
4/23/2018 9:12:33 PM(UTC)
Refrigerator too warm, Freezer too cold
by scm518
7/7/2015 4:40:12 AM(UTC)
Freezer too cold & refrigerator too warm
by dbdata
6/2/2015 5:00:32 PM(UTC)
GE Monogram 36" bottom freezer refrigerator - Freezer too cold @ -9 / Fridge at 44*F
by vfdfs2
8/17/2014 3:10:17 PM(UTC)
GE Profile freezer too cold, fridge seems okay
by chrispitude
12/29/2013 2:45:51 PM(UTC)
Fridge too warm, freezer too cold
by worstcase
10/20/2012 10:01:35 AM(UTC)
Freezer too cold/icing and everything shuts down
by LaurenG
10/15/2012 12:55:23 PM(UTC)
Fridge warm, freezer too cold and frosting
by Voltar
7/5/2012 6:15:57 PM(UTC)
Freezer Too Cold, Fridge Too Warm....
by dcoates
5/3/2012 9:16:19 AM(UTC)
Freezer too cold?
by skipdog77
2/1/2012 6:16:42 PM(UTC)
GE Profile freezer too cold, fridge too warm
by angpoon
1/4/2012 12:41:09 PM(UTC)
Freezer too cold, refrigerator too warm
by bandm59yakima
9/4/2011 1:31:28 PM(UTC)
