Frozen
#1 Posted : Thursday, April 2, 2009 5:25:52 PM(UTC)
Frozen
My freezer is too cold. I checked it a couple of days ago in a quest to find out why my electric bill has gone crazy. It was -20, so I reset the control. Next day it was 0 and I figured all was well. Tonight, it's -20 again. I opened the door and set the control to the lowest setting. The thermometer was at 0, a few minutes later it at -20 again. The freezer seems to be running even though the temperature is much too cold. I'm guessing bad thermostat, but I don't know much about freezers. There is no ice build-up inside and the seal appears good (it vacuums when closed). Also, I tried to clean the coils but can't find them. Are they behind a panel somewhere? One more symtom, may or may not be something. For months I've heard a buzzing at times, and it would stop if I tapped the side of the freezer. Now I'm not hearing that at all.
applianceman
#2 Posted : Thursday, April 2, 2009 6:56:46 PM(UTC)
applianceman
It’s possible that it is running all the time, which would mean that the cold control is bad. –20 for a deep freezer is not bad but frost-free freezers usually won’t get that low. I don’t believe this will cause your high electric bill. Freezers cost about $5 a month in electricity when operating properly and they run about 80% of the time when operating properly. So if it were running 100% of the time, it would only be a 20% increase and your electric bill would only go up about $1.00 a month. These numbers will vary with each model. Hope this helps!! Appliance Repair Guide For All Major Home Appliances [FONT='Times New Roman']Oh and there are no coils to clean on most freezers. [/FONT]
old maytag mtb1895 freezer too cold (Refrigerator & Freezer Repair)
by Guest 1/26/2022 8:49:08 PM(UTC)
Frigidaire FFHS2611PF, freezer too cold (Refrigerator & Freezer Repair)
by rleary78@gmail.com 1/26/2021 8:04:49 AM(UTC)
Compressor loud, runs constantly. Fridge/freezer too cold (Refrigerator & Freezer Repair)
by Plasticspaceman 4/15/2020 8:23:37 PM(UTC)
Freezer too cold, Ice build up causing leak (Refrigerator & Freezer Repair)
by Sgibb16 4/23/2018 9:12:33 PM(UTC)
Refrigerator too warm, Freezer too cold (Refrigerator & Freezer Repair)
by scm518 7/7/2015 4:40:12 AM(UTC)
Freezer too cold & refrigerator too warm (Refrigerator & Freezer Repair)
by dbdata 6/2/2015 5:00:32 PM(UTC)
GE Monogram 36" bottom freezer refrigerator - Freezer too cold @ -9 / Fridge at 44*F (Refrigerator & Freezer Repair)
by vfdfs2 8/17/2014 3:10:17 PM(UTC)
GE Profile freezer too cold, fridge seems okay (Refrigerator & Freezer Repair)
by chrispitude 12/29/2013 2:45:51 PM(UTC)
Fridge too warm, freezer too cold (Refrigerator & Freezer Repair)
by worstcase 10/20/2012 10:01:35 AM(UTC)
Freezer too cold/icing and everything shuts down (Refrigerator & Freezer Repair)
by LaurenG 10/15/2012 12:55:23 PM(UTC)
Fridge warm, freezer too cold and frosting (Refrigerator & Freezer Repair)
by Voltar 7/5/2012 6:15:57 PM(UTC)
Freezer Too Cold, Fridge Too Warm.... (Refrigerator & Freezer Repair)
by dcoates 5/3/2012 9:16:19 AM(UTC)
Freezer too cold? (Refrigerator & Freezer Repair)
by skipdog77 2/1/2012 6:16:42 PM(UTC)
GE Profile freezer too cold, fridge too warm (Refrigerator & Freezer Repair)
by angpoon 1/4/2012 12:41:09 PM(UTC)
Freezer too cold, refrigerator too warm (Refrigerator & Freezer Repair)
by bandm59yakima 9/4/2011 1:31:28 PM(UTC)
