bsmokey
#1 Posted : Thursday, November 15, 2007 6:04:05 PM(UTC)
bsmokey
I have a maytag washer that is making a metel on metel grinding noise ( like a bearing going bad ). It sounds as if it is coming from between the two tubs. Whats the trick to seperating the two tubs?:(
#2 Posted : Friday, November 16, 2007 5:21:23 PM(UTC)
The first thing I would recommend to do is remove the front panel and check for water leak from the central seal.
Sounds like the problem is a bad central bearing and usually it happens when the central seal is leaking.
Inspect the washer and post your findings.
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
Whirlpool, grinding badly at end of spin cycle (Washer Repair)
by cdestuck 2/6/2023 10:54:05 AM(UTC)
LG Washer - Rotor and Stator Grinding (Washer Repair)
by Guest 11/30/2022 7:57:29 PM(UTC)
Whirlpool Direct Drive Top Loader, grinding noise on spin start (Washer Repair)
by GRTison 5/1/2022 4:14:53 AM(UTC)
Maytag washer mvwb300wq2 has low grinding noise and won't turn on (Washer Repair)
by mzimmerman72 4/4/2022 2:01:41 PM(UTC)
Whirlpool wtw5000dw1 grinding and banging (Washer Repair)
by pcarlson 12/26/2021 5:17:03 AM(UTC)
Grinding with working agitator. (Washer Repair)
by Guest 9/23/2021 1:10:18 PM(UTC)
Whirlpool washer agitator working but with grinding noise (Washer Repair)
by Guest 9/23/2021 1:06:39 PM(UTC)
LG front load washer making grinding noise (Refrigerator & Freezer Repair)
by Guest 9/18/2021 8:57:25 AM(UTC)
Washing Machine Grinding Only in last minute of spin cycle... (Washer Repair)
by Jon_T 8/21/2021 11:15:16 AM(UTC)
GE Profile Quiet Power 2 - grinding noise BETWEEN stages? (Dishwasher Repair)
by Guest 8/19/2021 1:53:26 PM(UTC)
Whirlpool washer started making grinding noise (Washer Repair)
by apples99 6/30/2021 3:29:01 PM(UTC)
Grinding noise when running. (Washer Repair)
by Donaldbain007 5/30/2021 1:13:54 PM(UTC)
Kenmore 80 series won’t spin making grinding noise and smells burnt (Washer Repair)
by Liciasmommy 5/29/2021 2:00:00 PM(UTC)
